the third widget i give you to implement is a widget you can use to make to create a switch with up to 2 sensor values. you can add temperature outside and inside on your heatingswitch or the time the switch is automaticly turned on and off (only if you have a sensor with that time in HA) but you could also put the sunset en sunrise times in your switch.
please give me your ideas about combining.
you dont need to change any excisting files.
you need to create a new dir in your widgets dir and give it the name hasensorswitch.
then you make a file called hasensorswitch.coffee with the following code and save it in the new dir.
class Dashing.Hasensorswitch extends Dashing.ClickableWidget
constructor: ->
super
@queryState()
@accessor 'state',
get: -> @_state ? 'off'
set: (key, value) -> @_state = value
@accessor 'time1',
get: -> @_time1
set: (key, value) -> @_time1 = value
@accessor 'time2',
get: -> @_time2
set: (key, value) -> @_time2 = value
@accessor 'icon',
get: -> if @['icon'] then @['icon'] else
if @get('state') == 'on' then @get('iconon') else @get('iconoff')
set: Batman.Property.defaultAccessor.set
@accessor 'iconon',
get: -> @['iconon'] ? 'circle'
@accessor 'iconoff',
get: -> @['iconoff'] ? 'circle-thin'
@accessor 'icon-style', ->
if @get('state') == 'on' then 'switch-icon-on' else 'switch-icon-off'
toggleState: ->
newState = if @get('state') == 'on' then 'off' else 'on'
@set 'state', newState
return newState
queryState: ->
$.get '/homeassistant/switch',
widgetId: @get('id'),
(data) =>
json = JSON.parse data
@set 'state', json.state
if typeof @get('timea') isnt 'undefined'
$.get '/homeassistant/sensor',
widgetId: @get('timea'),
(data) =>
@set 'time1', json.value
if typeof @get('timeb') isnt 'undefined'
widgetId: @get('timeb'),
(data) =>
@set 'time2', json.value
postState: ->
newState = @toggleState()
$.post '/homeassistant/switch',
command: newState,
(data) =>
if json.error != 0
@toggleState()
ready: ->
if @get('bgcolor')
$(@node).css("background-color", @get('bgcolor'))
else
$(@node).css("background-color", "#444")
onClick: (event) ->
@postState()
the next code needs to be saved as hasensortext.html in the new dir
<h1 class="title" data-bind="title"></h1>
<h1 class="title2" data-bind="title2"></h1>
<h2 data-bind-class="icon-style"><i data-bind-class="icon | prepend 'fa fa-'"></i></h2>
<p class="time minus"><i class="title3" data-bind="time1"></i></p>
<p class="time plus"><i class="title3" data-bind="time2"></i></p>
and then you save the next code as hasensorswitch.scss in the new dir.
// Widget styles
.widget-hasensorswitch {
background-color: #444;
.title {
color: #fff;
margin-bottom: 5px;
margin-top: 5px;
.title2 {
color: #fff;
margin-bottom: 10px;
margin-top: 0px;
.title3 {
color: #fff;
margin-bottom: 5px;
margin-top: 10px;
align: left;
.switch-icon-off .switch-icon-on {
font-size: 150%;
.switch-icon-off {
color: #000000;
.switch-icon-on {
color: #aaff00;
.time {
position: absolute;
bottom: 3px;
width: 32px;
color: #fff;
&.plus {
right: 24px;
i {
padding-top: 10px;
padding-left: 10px;
&.minus {
left: 8px;
i {
padding-top: 10px;
padding-right: 15px;
then you are ready to edit your dashboard like this:
<li data-row="1" data-col="1" data-sizex="1" data-sizey="1">
<div data-id="your_switch_id" data-view="Hasensorswitch" data-icon="lightbulb-o" data-timea="your_first_sensor_id" data-timeb="your_second_sensor_id" data-title="any title" data-title2="more text" data-bgcolor="#FFDD55"></div>
</li>
when i created the widget i only thought about putting time in my switch widget so i could see the time the switch goes on and/or off. thats why i used time in my variable naming.
only after a while i realized that this combination can be used for some more projects.
maybe if it is like enough i will rewrite te naming to a more general nametype.
for those who need the same thing as input_boolean that is also possible.
make a dir with the name hasensorinputboolean, save the files again but with the name changed to hasensorinputboolean and change switch in the code (only at 3 places) for inputboolean.
after that you can use your Hasensorinputboolean in your dashboard.
here you can see how i use it with time off and time on:
