HADashboard not working properly Hassbian
Hey i just installed back hassbian ( had Hasio)
I was able to install Appdaemon and create folders with permission to home asstiance user
however i cannot link the entities to the dashboards.
I saw the log and get the following:
2018-11-17 15:12:55.877557 WARNING AppDaemon: HASS: ha_key is deprecated please use HASS Long Lived Tokens instead
2018-11-17 15:12:55.614857 INFO AppDaemon Version 3.0.2 starting
2018-11-17 15:12:55.615746 INFO Configuration read from: /home/homeassistant/appdaemon/appdaemon.yaml
2018-11-17 15:12:55.620567 INFO AppDaemon: Starting Apps
2018-11-17 15:12:55.622115 WARNING config_dir: /home exists, but is not writeable, owner: root
2018-11-17 15:12:55.629160 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-11-17 15:12:55.876859 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-11-17 15:12:55.878594 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-11-17 15:12:55.879700 INFO Starting Dashboards
2018-11-17 15:12:55.902070 INFO API is disabled
2018-11-17 15:12:55.917679 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:12:55.932645 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-11-17 15:13:00.957712 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:13:00.971935 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-11-17 15:13:05.985256 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:13:05.993349 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-11-17 15:13:11.017401 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:13:11.033410 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-11-17 15:13:16.060415 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:13:16.085199 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-11-17 15:13:21.110711 INFO AppDaemon: HASS: Connected to Home Assistant 0.82.1
2018-11-17 15:13:21.130461 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
How can i generate live token ?
Is this the only reason ?
Once i issue live token does it mean legacy password should be canceld ?
I managed to find a way to create token…
what name should i put for the token? in order to get hadashboard to work with hassbian?
