I have my home assistant and hadashboard running in a raspberry pi 3 and the official touchscreen. After reset, it is executed automatically chrome and load the hadashboard but the problem is that it is loaded before home assistant is ready so it appears with all the buttons as widget not found (or something like this).
How can I configure a reload of the hadashboard panel after X seconds or once the hass is ready? Could you give me an example please?
i would go the other way.
make sure that dashboard is up and running before you start chrome.
chrome is probably started by a service so add a waiting period there.
Thanks @ReneTode! As soon as I can, I will try what you suggest and tell you the results
Edited: I’ve tried the external command and it works perfectly. I have added a script that is executed at home assistant init and now the problem is solved. Thanks again
