I’ve had HA working for a while (ubuntu 18.04, pip3 install in venv) and got AppDaemon running fine (pip3 install, no venv) so it runs Hello.py. But no love from HADashboard. No problem for browsers (Firefox or Chrome) to connect to HA server (:8123), but all browsers time out on the HADashboard server (:5050).
Config file looks like this
appdaemon:
threads: 10
disable_apps: 1
plugins:
HASS:
type: hass
ha_url: http://192.168.xxx.xxx:8123
token: <very long string>
log:
errorfile: /var/log/appdaemon.log
logfile: /var/log/appdaemon.log
accessfile: /var/log/appdaemon.log
hadashboard:
dash_url: http://192.168.xxx.xxx:5050
dash_force_compile: 1
Log looks like this
2019-07-03 11:48:03.634621 INFO AppDaemon Version 3.0.5 starting
2019-07-03 11:48:03.634750 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2019-07-03 11:48:03.635447 INFO AppDaemon: Starting Apps
2019-07-03 11:48:03.635597 WARNING config_dir: /home exists, but is not writeable, owner: root
2019-07-03 11:48:03.637474 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2019-07-03 11:48:03.718922 INFO AppDaemon: HASS: HASS Plugin Initializing
2019-07-03 11:48:03.719144 INFO AppDaemon: HASS: HASS Plugin initialization complete
2019-07-03 11:48:03.719247 INFO Starting Dashboards
2019-07-03 11:48:03.719618 WARNING css: /home exists, but is not writeable, owner: root
2019-07-03 11:48:03.719872 WARNING javascript: /home exists, but is not writeable, owner: root
2019-07-03 11:48:03.721294 INFO API is disabled
2019-07-03 11:48:03.725560 INFO AppDaemon: HASS: Connected to Home Assistant 0.93.2
2019-07-03 11:48:03.736950 INFO AppDaemon: Got initial state from namespace default
2019-07-03 11:48:05.739289 INFO AppDaemon: Reading config
2019-07-03 11:48:05.741238 INFO AppDaemon: /home/homeassistant/conf/apps/apps.yaml added or modified
2019-07-03 11:48:05.741401 INFO AppDaemon: /home/homeassistant/conf/apps/apps.yaml added or modified
2019-07-03 11:48:05.741525 INFO AppDaemon: App 'hello_world' added
2019-07-03 11:48:05.741697 INFO AppDaemon: Adding /home/homeassistant/conf/apps to module import path
2019-07-03 11:48:05.741971 INFO AppDaemon: Loading App Module: /home/homeassistant/conf/apps/hello.py
2019-07-03 11:48:05.748970 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module hello
2019-07-03 11:48:05.769229 INFO hello_world: Hello from AppDaemon
2019-07-03 11:48:05.769506 INFO hello_world: You are now ready to run Apps!
2019-07-03 11:48:05.769734 INFO AppDaemon: App initialization complete
