Hello
I have had a strange problem in recent weeks. I use the alexa media player extension. every time i restart it stops working, But if I run the command, “ha core rebuild” via ssh then it starts to work again, however it is slightly annoying to do every time I restart. If I do not, it will not be able to remove or add it again, I have tried installing it several times and also tested different versions but I get the same problem all the time. anyone who has a thought on how to solve this? im running HA on a nuc using nuc image //Sincerely
