I just received a HA Green box but it seems there is some problem ongoing during the installation.
I plugged the Box with Ethernet, then alimentation, and after some minutes, when I connect to homeassistant.local:8123, I can see on console the following error :
[supervisor.jobs] ‘Updater.fetch_data’ blocked from execution, no supervisor internet connection
What do I have to do to unblock this operation ?
Thank you in advance
Ok, I did find the problem at the end. I have a router around, which had his DHCP server on too. I disable its DHCP server and everything is runing smooth now !
Thanks for the help
