New dashboard
Hi, this Dashboard is amazing. But it seems there is a card_title template missing. It would be nice if you can help me.
thx
I see I forgot to include the template…
Here it is, its a modified version of GitHub - UI-Lovelace-Minimalist/UI: UI-Lovelace-Minimalist is a "theme" for HomeAssistant title card.
button_card_templates:
card_title:
tap_action:
action: none
show_icon: false
show_label: true
show_name: true
styles:
card:
- background-color: rgba(0,0,0,0)
- box-shadow: none
- height: auto
- width: auto
grid:
- grid-template-areas: '''n'' ''l'''
- grid-template-columns: 1fr
- grid-template-rows: min-content min-content
name:
- justify-self: start
- font-weight: bold
label:
- font-weight: bold
- font-size: 1rem
- opacity: '0.4'
list_2_items:
styles:
grid:
- grid-template-areas: '''item1 item2'''
- grid-template-columns: 1fr 1fr
- column-gap: 7px
card:
- box-shadow: none
- padding: 0px
thx it works now. But what with these views files? Where should i insert those yaml files?
I have also updated the 00- raw view.yaml on the github repo to include all of my code.
Hi, How did you create the sensor.weather_info_tutorial?
The sensor came from https://www.youtube.com/@My_Smart_Home.
Add this to the config file: template: !include templates.yaml and then create a new file called templates.yaml
The code is placed under templates.yaml
- sensor:
- name: "Weather Info English"
unique_id: "weather_info_eng"
state: >
{% set weather = states('weather.forecast_home') %}
{% if is_state('sun.sun', 'above_horizon') %}
{{ '/local/weather/' + weather + '.svg' }}
{% else %}
{{ '/local/weather/' + weather + '_night.svg' }}
{% endif %}
attributes:
temp: >
{{ state_attr('weather.forecast_home', 'temperature') }}
feels_like: >
{% set T = (state_attr('weather.forecast_home', 'temperature') | float) %}
{% set K = (state_attr('weather.forecast_home', 'wind_speed') | float)/3.6 %}
{% set V = (K/1000*60*60) %}
{% set A = 13.12 + 0.6215*T - 11.37*(V**0.16) + 0.3965*T*(V**0.16) %}
{{ (A) | round(1) }}
desc: >
{{ states('weather.forecast_home') }}
precipitation: >
{{ state_attr('weather.forecast_home', 'forecast')[0].precipitation }}
precipitation_percent: >
{{ state_attr('weather.forecast_home', 'forecast')[0].precipitation_probability }}
wind_dir: >
{% set direction = ['N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW', 'N'] %}
{% set degree = state_attr('weather.forecast_home', 'wind_bearing')|float %}
{{ direction[((degree+11.25)/22.5)|int] }}
wind_speed: >
{% set sensor = state_attr('weather.forecast_home', 'wind_speed') | float %}
{{ (sensor / 3.6) | round(1) }}
wind_desc: >
{% if sensor > 0 and sensor < 0.99 %}
Calm
{% elif sensor > 1 and sensor < 6.99 %}
Light air
{% elif sensor > 7 and sensor < 11.99 %}
Light breeze
{% elif sensor > 12 and sensor < 19.99 %}
Gentle breeze
{% elif sensor > 20 and sensor < 29.99 %}
Moderate breeze
{% elif sensor > 30 and sensor < 39.99 %}
Fresh breeze
{% elif sensor > 40 and sensor < 50.99 %}
Strong breeze
{% elif sensor > 51 and sensor < 62.99 %}
Near gale
{% elif sensor > 63 and sensor < 75.99 %}
Gale
{% elif sensor > 76 and sensor < 87.99 %}
Strong gale
{% elif sensor > 88 and sensor < 102.99 %}
Storm
{% elif sensor > 103 and sensor < 117.99 %}
Violent storm
{% else %}
Hurrican
{% endif %}
