Haier HoN integration not working anymore
I can’t get my AC back in HA again. It started with error messages in HA when turning the AC off so I tried reloading the intergration but then things went wrong completely. The installation failed, check logs.
I changed my password for the Hon app, removed the intergration from HA, removed download from HACS and started all over again with no luck whatsoever. The HoN app works fine but the HA integration fails to setup but logging in works.
Maybe someone here can help me.
same problem here!!!
Same problem!
If you have a problem with a specific custom integration, your first step should be to check the original GitHub post where you found it. The people there know the product and use the software, so they can give you better help with your issue. You might find someone here who can help, but it’s not guaranteed.
Found my solution overhere:
SSL unable to get local issuer certificate · Issue #285 · Andre0512/hon
It was a pain for me to get it to work again, but that’s because I’m a complete noob with these things but I did it, so I think anyone can :wink:
import logging
from pathlib import Path
from typing import Any
import voluptuous as vol  # type: ignore[import-untyped]
from homeassistant.config_entries import ConfigEntry
from homeassistant.const import CONF_EMAIL, CONF_PASSWORD
from homeassistant.helpers import config_validation as cv, aiohttp_client
from homeassistant.helpers.typing import HomeAssistantType
from homeassistant.helpers.update_coordinator import DataUpdateCoordinator
from pyhon import Hon
from .const import DOMAIN, PLATFORMS, MOBILE_ID, CONF_REFRESH_TOKEN
_LOGGER = logging.getLogger(__name__)
HON_SCHEMA = vol.Schema(
        vol.Required(CONF_EMAIL): cv.string,
        vol.Required(CONF_PASSWORD): cv.string,
CONFIG_SCHEMA = vol.Schema(
    {DOMAIN: vol.Schema(vol.All(cv.ensure_list, [HON_SCHEMA]))},
    extra=vol.ALLOW_EXTRA,
async def async_setup_entry(hass: HomeAssistantType, entry: ConfigEntry) -> bool:
    session = aiohttp_client.async_get_clientsession(hass)
    if (config_dir := hass.config.config_dir) is None:
        raise ValueError("Missing Config Dir")
    hon = await Hon(
        email=entry.data[CONF_EMAIL],
        password=entry.data[CONF_PASSWORD],
        mobile_id=MOBILE_ID,
        session=session,
        test_data_path=Path(config_dir),
        refresh_token=entry.data.get(CONF_REFRESH_TOKEN, ""),
    ).create()
    # Save the new refresh token
    hass.config_entries.async_update_entry(
        entry, data={**entry.data, CONF_REFRESH_TOKEN: hon.api.auth.refresh_token}
    coordinator: DataUpdateCoordinator[dict[str, Any]] = DataUpdateCoordinator(
        hass, _LOGGER, name=DOMAIN
    hon.subscribe_updates(coordinator.async_set_updated_data)
    hass.data.setdefault(DOMAIN, {})
    hass.data[DOMAIN][entry.unique_id] = {"hon": hon, "coordinator": coordinator}
    # Forward config entry setup to all platforms
    hass.async_create_task(
        hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
    return True
async def async_unload_entry(hass: HomeAssistantType, entry: ConfigEntry) -> bool:
    refresh_token = hass.data[DOMAIN][entry.unique_id]["hon"].api.auth.refresh_token
        entry, data={**entry.data, CONF_REFRESH_TOKEN: refresh_token}
    unload = await hass.config_entries.async_unload_platforms(entry, PLATFORMS)
    if unload:
        if not hass.data[DOMAIN]:
            hass.data.pop(DOMAIN, None)
    return unload
Replace content of init.py with this code and will work again
I have this login problem :
import logging
    hon = await Hon(
        session=session,
    ).create()
    return True
    if unload:
    return unload
So guys please let me know, if the HoN integration works now (i am thinking to buy a Haier/Hoover oven)?
Great, thanks!
Any chance this can get merged into the official repository?
As by October 30th I cannot control anymore the Haier AC in my Home Assistant, even using the SSL certificate and the GitHub - gvigroux/hon: Support of all Haier, Candy, Hoover appliances integrated in the official hOn mobile app. Direct access to all possible services and parameters branch.
Edit: For some reason, even with the password working on the app, the fix was resetting the password and adding the new one in HA.
After that, both app and HA are working fine.
