This flow may look a bit complicated but mimics how the Philips Hue Hub deals with motion.
Based on the time and light level it will turn the lights on when motion is detected.
It then checks if there is motion for 30 seconds, every second before dimming lights
It then checks for motion for the next 30 seconds, every second before turning off the lights
If at any point motion is detected it turns the lights back to its preset brightness and starts motion detection from the beginning again.
With some exceptions:
After 23.00 the lights are set to dim so it doesn’t dim them after 30 seconds but checks for motion for every second for 60 seconds before turning them off.
If the alarm is not disarmed then this flow is not triggered - I have different settings for this when alarm is armed and triggered
I’m using Hue Motion sensors so they re-trigger quickly. Other motion sensors may not but this works well with the setup I have.
You may need to change your entities names in the nodes in this flow and also add your longitude/latitude to the time interval nodes.
[{"id":"424d9ac3.5584d4","type":"time-range-switch","z":"fe3260af.8794a","name":"","lat":"","lon":"","startTime":"23:00","endTime":"sunrise","startOffset":0,"endOffset":"-60","x":1080,"y":260,"wires":[["203ed480.2c666c"],["3af12b2.4c782d4"]]},{"id":"6e259947.91879","type":"server-state-changed","z":"fe3260af.8794a","name":"Hallway Motion Detected","server":"60e1db70.15c0ec","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":250,"y":260,"wires":[["5651771c.45784"],[]]},{"id":"cddd65bf.d0199","type":"api-current-state","z":"fe3260af.8794a","name":"Halway Lux","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"24","halt_if_type":"num","halt_if_compare":"lt","override_topic":false,"entity_id":"sensor.hallway_motion_sensor_light_level","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":870,"y":260,"wires":[["424d9ac3.5584d4"],[]]},{"id":"3af12b2.4c782d4","type":"api-call-service","z":"fe3260af.8794a","name":"turn on hallway lights","server":"60e1db70.15c0ec","version":1,"debugenabled":false,"service_domain":"scene","service":"turn_on","entityId":"scene.hallway_tropical_twilight","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1340,"y":260,"wires":[[]]},{"id":"5651771c.45784","type":"api-current-state","z":"fe3260af.8794a","name":"Check Disarmed Status","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"disarmed","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"alarm_control_panel.house","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":510,"y":260,"wires":[["6a0466ff.f2e66"],[]]},{"id":"6a0466ff.f2e66","type":"delay","z":"fe3260af.8794a","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":260,"wires":[["cddd65bf.d0199"]]},{"id":"ad328435.e0ca8","type":"api-call-service","z":"fe3260af.8794a","name":"Dim hallway lights","server":"60e1db70.15c0ec","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_lights","data":"{\"brightness_pct\":\"10\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1550,"y":420,"wires":[["94e778ef.c10898"]]},{"id":"c0efba0d.362bf","type":"api-call-service","z":"fe3260af.8794a","name":"turn off hallway lights","server":"60e1db70.15c0ec","version":1,"service_domain":"light","service":"turn_off","entityId":"group.hallway_lights_group","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":2280,"y":420,"wires":[[]]},{"id":"f04ce98a.5442e","type":"api-current-state","z":"fe3260af.8794a","name":"Check Disarmed Status","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"disarmed","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"alarm_control_panel.house","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":510,"y":420,"wires":[["9192cf29.2589d"],[]]},{"id":"461f2314.0ff6dc","type":"time-range-switch","z":"fe3260af.8794a","name":"","lat":"","lon":"","startTime":"23:00","endTime":"sunrise","startOffset":0,"endOffset":"-60","x":800,"y":420,"wires":[["f291b906.96697"],["22f9ad9f.f0caa2"]]},{"id":"fbea3a58.cd7648","type":"server-state-changed","z":"fe3260af.8794a","name":"Hallway Motion Detected","server":"60e1db70.15c0ec","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.hallway_motion_sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":270,"y":420,"wires":[["f04ce98a.5442e"],[]]},{"id":"22f9ad9f.f0caa2","type":"api-current-state","z":"fe3260af.8794a","name":"Check Motion","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.hallway_motion_sensor","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1040,"y":420,"wires":[[],["ce8a0f2a.6c3d1"]]},{"id":"94e778ef.c10898","type":"api-current-state","z":"fe3260af.8794a","name":"Check Motion","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.hallway_motion_sensor","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1780,"y":420,"wires":[["424d9ac3.5584d4"],["d5f89f14.c0efa8"]]},{"id":"a18ee953.7ebe4","type":"delay","z":"fe3260af.8794a","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":2019,"y":500,"wires":[["94e778ef.c10898"]]},{"id":"d5f89f14.c0efa8","type":"counter-loop","z":"fe3260af.8794a","name":"","counter":"ile86d4036d62498","counterType":"msg","reset":true,"resetValue":"value-null","initial":0,"initialType":"num","operator":"lt","termination":"31","terminationType":"num","increment":1,"incrementType":"num","x":2020,"y":420,"wires":[["c0efba0d.362bf"],["a18ee953.7ebe4"]]},{"id":"ce8a0f2a.6c3d1","type":"counter-loop","z":"fe3260af.8794a","name":"","counter":"ile86d4036d62498","counterType":"msg","reset":true,"resetValue":"value-null","initial":0,"initialType":"num","operator":"lt","termination":"31","terminationType":"num","increment":1,"incrementType":"num","x":1280,"y":420,"wires":[["ad328435.e0ca8"],["8656a797.318f1"]]},{"id":"8656a797.318f1","type":"delay","z":"fe3260af.8794a","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1180,"y":500,"wires":[["22f9ad9f.f0caa2"]]},{"id":"203ed480.2c666c","type":"api-call-service","z":"fe3260af.8794a","name":"turn on hallway lights dim","server":"60e1db70.15c0ec","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hallway_lights","data":"{\"brightness_pct\":\"30\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1350,"y":220,"wires":[[]]},{"id":"505295af.695e04","type":"api-call-service","z":"fe3260af.8794a","name":"turn off hallway lights","server":"60e1db70.15c0ec","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.hallway_lights","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1260,"y":700,"wires":[[]]},{"id":"f291b906.96697","type":"api-current-state","z":"fe3260af.8794a","name":"Check Motion","server":"60e1db70.15c0ec","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.hallway_motion_sensor","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":900,"y":640,"wires":[[],["42bf161a.09baa"]]},{"id":"a7f6a3db.667ef","type":"delay","z":"fe3260af.8794a","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1080,"y":680,"wires":[["f291b906.96697"]]},{"id":"42bf161a.09baa","type":"counter-loop","z":"fe3260af.8794a","name":"","counter":"ile86d4036d62498","counterType":"msg","reset":true,"resetValue":"value-null","initial":0,"initialType":"num","operator":"lt","termination":"61","terminationType":"num","increment":1,"incrementType":"num","x":880,"y":700,"wires":[["505295af.695e04"],["a7f6a3db.667ef"]]},{"id":"ab7ee7cf.53231","type":"comment","z":"fe3260af.8794a","name":"................... Hallway Lights Motion Presence .................. ................... 2 Preset Light Levels - Hue Motion Presence..................","info":"","x":680,"y":160,"wires":[]},{"id":"56ee0f9b.e5f5d8","type":"api-current-state","z":"fe3260af.8794a","name":"Hallway Lights","server":"57ce5691.fd6e48","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"group.hallway_lights_group","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":640,"y":540,"wires":[["461f2314.0ff6dc"],[]]},{"id":"9192cf29.2589d","type":"delay","z":"fe3260af.8794a","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":620,"y":480,"wires":[["56ee0f9b.e5f5d8"]]},{"id":"87ddd38f.c0fd7","type":"comment","z":"fe3260af.8794a","name":"Lights already dim so check if motion is in next 60 seconds else turn lights off ","info":"","x":1090,"y":600,"wires":[]},{"id":"92d9c7cb.343b78","type":"comment","z":"fe3260af.8794a","name":"Turn on Lights Flow ---->","info":"","x":270,"y":220,"wires":[]},{"id":"98d5d4c2.e068c8","type":"comment","z":"fe3260af.8794a","name":"Check for motion before turning off lights ---->","info":"","x":350,"y":360,"wires":[]},{"id":"60e1db70.15c0ec","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"57ce5691.fd6e48","type":"server","name":"Home Assistant","addon":true}]
