HAMA Thermostat 176592 + Zigbee2mqtt - heating: NULL with applicationVersion”: 85
With 3 pieces (I get the status “Heating”), with 10 pieces no status.
The only difference is the applicationVersion:
  • 3x “applicationVersion”: 67 works: “heating”: “ON”
         "anti_scaling": "ON",
         "away_mode": "OFF",
         "battery_low": false,
         "child_lock": "LOCK",
         "current_heating_setpoint": 16,
         "device": {
             "applicationVersion": 67,
             "dateCode": "",
             "friendlyName": "thermostat-fitnessraum2",
             "hardwareVersion": 1,
             "ieeeAddr": "0xa4c138dd160d7831",
             "manufacturerID": 4417,
             "manufacturerName": "_TZE200_h4cgnbzg",
             "model": "SEA801-Zigbee/SEA802-Zigbee",
             "networkAddress": 28931,
             "powerSource": "Battery",
             "stackVersion": 0,
             "type": "EndDevice",
             "zclVersion": 3
         "frost_detection": "ON",
         "heating": "OFF",  <------
         "last_seen": "2024-01-12T13:00:38+01:00",
         "linkquality": 255,
         "local_temperature": 17,
         "local_temperature_calibration": 0,
         "preset_mode": "none",
         "system_mode": "heat",
         "window_detection": "ON",
         "elapsed": 3241
  • 10x “applicationVersion”: 85 not working: “heating”: null
        "away_mode": "OFF",
        "child_lock": "UNLOCK",
        "current_heating_setpoint": 18,
        "device": {
            "applicationVersion": 85,
            "dateCode": "",
            "friendlyName": "thermostat-fitnessraum",
            "ieeeAddr": "0x5c0272fffea346d5",
            "manufacturerID": 4098,
            "manufacturerName": "_TZE200_yw7cahqs",
            "networkAddress": 25693,
            "stackVersion": 0,
            "zclVersion": 3
    	"heating": null   <------
        "last_seen": "2024-01-12T13:37:29+01:00",
        "linkquality": 255,
        "local_temperature": 19,
        "elapsed": 390141,
Do I need to update the firmware for the 10 and how can I do that or is there another solution?
Thanks.
