Handling errors
I have an automation that errored. How do I trap these errors and restart when it happens.
continue_on_error
Is it possible to set continue_on_error from GUI or do I have to edit in YAML mode? My actions are as follows and I am confused where to set continue_on_error. I want to set it for each service call so if any one or two or even three devices fail for some reason, the automation just continues to run the actions.
  - service: switch.turn_off
      entity_id: switch.curtain_light
    data: {}
      entity_id: switch.led_plant
    data: {}
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
      entity_id: switch.upstairs_window_curtain_lights
    data: {}
    data: {}
      entity_id:
        - switch.outdoor_holiday_lights_garage
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
    data: {}
      entity_id: switch.indoor_holiday_lights
    data: {}
      entity_id:
        - switch.outdoor_holiday_lights_porch_1
        - switch.outdoor_holiday_lights_porch_2
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - service: script.turn_on
    data: {}
      entity_id: script.post_light_on
mode: single
Thanks,
It is too bad the continue_on_error: “feature” has never worked! I have some automation for leak detection, security, and other important functions. Most of them are fairly complex with a number of different actions and triggers. When multiple entities are involved, there is always one that is not connected for whatever reason. For example, if I have a leak, my automation is set up to notify my cell phone, send tts to Google speakers, flash some lights, etc. If there is a problem with an entity at the beginning of the automation, I may not get any notification of the leak. Continue_on_error: would make the system more reliable and dependable. Hopefully, the developers will fix it since they made a big thing about it during it’s rollout earlier this year!
