Is what I notice intentional to this release? I can’t find it in the release notes.
On 0.38.4, the attribute last_updated of a z-wave wall plug only updates to the current time when the actual value of the state changes i.e. from 0.0w to 5.2w. It doesn’t update when a z-wave report comes in which has the same value (i.e. state is 0.0w and new report is also 0.0w).
On 0.39.1 the value last_updated is updated when a new report with the same value for state is sent to home assistant.
For device_tracker.owntracks when i’m already home and my location updates, but inside the home.zone, my automation does not trigger on 0.38.4.
On 0.39.1 it is triggering my automation.
Is handling of states and/or events changed in release 0.39 causing this behaviour?
Is this intentional or a bug?
there are two attributes, last_updated and last_changed. If i read this correctly last_updated should be updated when my wall_plug sends a new report (0.0w to 0.0w) and last_changed should not change in that situation.
When a report comes with a changed value (0.0w to 5.2w) both last_changed and last_updated should change.
However this does not explain why my ‘getting home’ automation triggers right?
Trigger:
platform: state
entity_id: device_tracker.xx
to: home
Should only trigger if state is changed right? ‘to: home’ without a ‘from’ for me implies a ‘from: any zone’
@thrust15 a new state (any change in coords or battery) will trigger this automation, even if the previous state was ‘home’
if you want the ‘from: any zone’ you need a condition using the trigger.from_state.state
@Bart274 I don’t understand. I reverted back to 0.38.4 and I can update my coordinates via OwnTracks while home without triggering the automation. This has been the case for several releases, I started using this automation in 0.35 or 0.36
The behavior changed in 0.39.1 where it would trigger on every change.
I think this is an unintentional side effect from a change. In this release.
