mishaVee
(michael)
July 2, 2023, 7:01am
1
I have a restful command and can’t work out how to handle the 201 response from the API. My setup is:
rest_command:
cycle_state:
url: 'http://127.0.0.1:5000/cycle'
method: post
headers:
Authorization: !secret token
Content-Type: 'application/json'
payload: '{"name": "1", "length": 10, "status": true, "delay_enabled": false, "start_date": "2023-07-04T00:00:00Z"}'
switch:
switches:
automation_switch:
friendly_name: "Automation Start/Stop"
value_template: "{{ is_state('input_boolean.automation_status', 'on') }}"
turn_on:
entity_id: input_boolean.automation_status
- service: rest_command.cycle_state
turn_off:
- service: input_boolean.turn_off
any advice or resources would be great
koying
(Chris B)
July 2, 2023, 7:54am
2
A rest_command ignores the reply from the endpoint.
What do you want to do with the 201?
mishaVee
(michael)
July 2, 2023, 8:03am
3
@koying thanks for that, I’m trying to set a sensor entity with the returned value. i.e in this case the returned payload is:
"id": "123",
"message": "Cycle created"
I haven’t included my sensor setup as its a big mess of trying different things. as of now i have:
- platform: rest
resource: http://127.0.0.1:5000/cycle
method: POST
headers:
value_template: '{{ value_json.id }}'
scan_interval: 10
json_attributes:
- id
- message
mishaVee
(michael)
July 2, 2023, 8:06am
4
Sorry i should add the above works, I forgot to include the payload. its not exacly what i wanted but i should be able to trigger the sensor based on a switch as apposed to the scan time
koying
(Chris B)
July 2, 2023, 8:16am
5
A solution could be to define a restful sensor (RESTful - Home Assistant ) with an absurdly long scan_interval
, then use the homeassistant.update_entity
to “update” it when needed. This way, you’ll be able to capture the id
NOTE : Be careful though that you cannot prevent HA to update the sensor once at HA startup, so that might be a stopper for you.
mishaVee
(michael)
July 2, 2023, 8:21am
6
good point on the intial sensor update. will need to do a little thinking
