Okay so this has been more complicated than I envisaged due to the fact the HA resets the last_changed value of sensors when restarting (when e.g. testing new config) so as per Real state last_changed and a reimplementation for SQLite, a bunch of new “proxy” sensors (rlc_) which store real time since last change as an hourly value, I have finished the script which will:
- Take either automation or climate as setting to check/switch off
- Work with either single or multiple values for automation/climate
- Have a quick yaml parse to check for errors
It is all in the notebook linked above, but for those that prefer reading in the forum here is the code that I have tested and working well:
# escape any ' with ''
settings = [
{"id": "attic_office_stale",
"alias": "Attic Office",
"sensor": "attic_office_temperature",
"rlc_sensor": "rlc_attic_office_temperature",
"timeout": 4,
"automations": ["attic_heating_on","attic_heating_on_f"]},
{"id": "pip_room_stale",
"alias": "Pip''s room",
"sensor": "pip_temperature",
"rlc_sensor": "rlc_pip_temperature",
"timeout": 4,
"automations": ["turn_pip_s_heating_on"]},
{"id": "kitchen_stale",
"alias": "Kitchen",
"sensor": "kitchen_temperature",
"rlc_sensor": "rlc_kitchen_temperature",
"timeout": 4,
"automations": ["kitchen_heating_on"]},
{"id": "tackroom_stale",
"alias": "Tackroom",
"sensor": "tackroom_temperature",
"rlc_sensor": "rlc_tackroom_temperature",
"timeout": 4,
"climates": ["tack_room"]},
{"id": "greenhouse_stale",
"alias": "Greenhouse",
"sensor": "greenhouse_temperature",
"rlc_sensor": "rlc_greenhouse_temperature",
"timeout": 4,
"climates": ["greenhouse"]},
{"id": "hot_water_stale",
"alias": "Hot Water",
"sensor": "hot_water",
"rlc_sensor": "rlc_hot_water",
"timeout": 4,
"automations": ["hot_water_bath","hot_water"]}
config=""
for item in settings:
if "automations" in item:
is_automation = True
is_climate = False
elif "climates" in item:
is_automation = False
is_climate = True
else:
raise Exception(f"No automations or climates defined for {item['id']}")
config += f"""
- id: '{item["id"]}'
alias: 'Stale sensor: {item["alias"]}'
description: ''
- platform: time_pattern
minutes: 7
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.{item["rlc_sensor"]}
above: '{item["timeout"]}'
if (is_automation and len(item["automations"]) > 1) or is_climate and len(item["climates"]) >1:
config += f"""
- condition: or
conditions:
if is_automation:
for automation in item["automations"]:
config += f"""
- condition: state
entity_id: automation.{automation}
state: 'on'
elif is_climate:
for climate in item["climates"]:
config+= f"""
- condition: state
entity_id: climate.{item["climate"]}
state: heat
elif is_automation:
config+=f"""
- condition: state
entity_id: automation.{item["automations"][0]}
state: 'on'
elif is_climate:
config+=f"""
- condition: state
entity_id: climate.{item["climates"][0]}
state: heat
config += f"""
if is_automation:
config += f"""
- data: {{}}
service: automation.turn_off
elif is_climate:
config += f"""
- data: {{}}
entity_id: climate.{automation}
service: climate.turn_off
config += f"""
- data:
message: Disabling {item["alias"]}
title: 'Stale sensor: {item["sensor"]}'
service: notify.mobile_app_pixel_2
try:
yaml.safe_load(config)
print(config)
except:
print("YAML failed to parse")
I decided not to automatically re-enable automations/climates and skip the NA sensor view. The notifications to my mobile phone work well enough.
