Handling user form with multiple devices
I’m building a custom component which find multiple devices on the network by UDP broadcast.
The result is self.devices which contains a list of dictionaries with discovered devices.
        'sn': 'SWP1023002004971',
        'name': 'Chambre',
        'pname': None,
        'ip': '172.30.47.99',
        'ver': '1.30'
        'sn': 'SWP6023002003697',
        'name': 'Salon',
        'pname': ['Bravia', 'Ampli', 'HUE', 'Transporter', 'HP', 'Wifi'],
        'ip': '172.30.47.165',
        'ver': '1.30'
        'sn': 'SWP6023002002386',
        'name': 'Veranda',
        'pname': None,
        'ip': '172.30.47.162',
        'ver': '2.11'
        'sn': 'SWP6023002002466',
        'name': 'Cuisine',
        'pname': None,
        'ip': '172.30.47.167',
        'ver': '2.11'
I have then a loop to step import which works fine. It creates one entry per device.
            for device in self.devices:
                await self.hass.config_entries.flow.async_init(
                    DOMAIN,
                    context={"source": config_entries.SOURCE_IMPORT},
                    data=device
What I would like to do is, before proceeding to this loop, I want to ask the user a new name and 6 port names and update self.devices accordingly for each device with version 2.11. I already perpared the schema for that:
DATA_SCHEMA_2_11 = vol.Schema(
        vol.Required("device_name", description="Device Name"): str,
        vol.Required("port1_name", description="Port 1 Name"): str,
        vol.Optional("port2_name", description="Port 2 Name"): str,
        vol.Optional("port3_name", description="Port 3 Name"): str,
        vol.Optional("port4_name", description="Port 4 Name"): str,
        vol.Optional("port5_name", description="Port 5 Name"): str,
        vol.Optional("port6_name", description="Port 6 Name"): str,
I don’t understand how I can make such a loop in the config flow.
I thought of making a async_step_V2_11 method. But how to proceed from there ? Can anyone point me in the right direction ?
In summary, I want:
for device in self.devices => if ver = 2 .11 => as user for name and port names => update device dictionnary
If you can post a link to your code this may help.
However, it looks like you are calling a config flow for each discovered device. As such, the user input form would be called each time for each device (as this is within the flow).
Is it not better to discover each device seperately (show them as a discovered device) and then follow a common flow, with form for your name and port if v2.11 as each device is added?
Whats the reason for trying to bulk add these?
Hi @msp1974 Mark and everyone.
I gave a lot of thoughts on making one entry for all devices or a single entry per devices. I ended deciding for one per device for ease of entry management.
If I understand what you say, you think of something like Shelly where each device is individually configured and hence run their own config flow.
A difficulty I have is I want the devices to be discovered automatically, but discovery is made with a UDP broadcast, and all devices are returned at once.
Anyway, this works fine, I have no issue with this part. And I also was able for a while to loop through user input since I posted this question.
However, I’ve been trying to improve stuff but now I’m stuck on something stupid, most probably a mistake I make, but I cannot figure out what it is.
This is how my config flow looks. I didn’t publish yet this version because my github is a bit messy and I have to work it out.
The problem I have now is the following:
From user step, I call udp_discovery step. From that step, if devices have been discovered, I call the process_data step for each discovered device.
In the process_data step, this part (line 214 and below) “Choose the appropriate schema based on the number of ports and version” works fine. However, once user input has been provided, self.device_data is reset, and only contains value provided by user. I lose the original part that I need to keep.
Here is the content of self.device_data at first run:
{'sn': 'SWP1023002004971', 'name': 'Chambre', 'pname': None, 'ip': '172.30.47.99', 'ver': '1.30'}
And here, at second run after user input has been provided:
{'device_name': 'Chambre', 'port1_name': 'Filtre à air'}
But the expected output at second run should be:
{'sn': 'SWP1023002004971', 'name': 'Chambre', 'pname':['Filtre à air'], 'ip': '172.30.47.99', 'ver': '1.30'}
And I really can’t find where the issue is. I spent already more than 10 hours on this :exploding_head:
If anyone can see what I am missing (or misunderstanding from how the flow works), I would really appreciate the help.
import logging
import ipaddress
from homeassistant import config_entries, exceptions
from homeassistant.const import CONF_IP_ADDRESS
import voluptuous as vol
from maxsmart import MaxSmartDiscovery, MaxSmartDevice
from .const import (
    DOMAIN,
    CONF_DEVICE_NAME,
    CONF_PORT1_NAME,
    CONF_PORT2_NAME,
    CONF_PORT3_NAME,
    CONF_PORT4_NAME,
    CONF_PORT5_NAME,
    CONF_PORT6_NAME,
    CONF_ADD_MORE,
_LOGGER = logging.getLogger(__name__)
# Schema for devices with version 2.11
DATA_SCHEMA_MULTI_PORTS = vol.Schema(
        vol.Required(CONF_DEVICE_NAME, description="Device Name"): vol.All(
            str, vol.Length(min=1)
        vol.Required(CONF_PORT1_NAME, description="Port 1 Name"): vol.All(
        vol.Required(CONF_PORT2_NAME, description="Port 2 Name"): vol.All(
        vol.Required(CONF_PORT3_NAME, description="Port 3 Name"): vol.All(
        vol.Required(CONF_PORT4_NAME, description="Port 4 Name"): vol.All(
        vol.Required(CONF_PORT5_NAME, description="Port 5 Name"): vol.All(
        vol.Required(CONF_PORT6_NAME, description="Port 6 Name"): vol.All(
# Schema for manual device addition
DATA_SCHEMA_MANUAL = vol.Schema(
        vol.Required(CONF_IP_ADDRESS): str
# Schema for overwriting existing device
DATA_SCHEMA_OVERWRITE = vol.Schema(
        vol.Required("overwrite", description="Overwrite existing entry?"): vol.In(
            ["Yes", "No"]
DATA_SCHEMA_ADD_MORE = vol.Schema(
        vol.Required(CONF_ADD_MORE, description="Add more devices?"): vol.In(
            ["Yes", "No"]
def is_valid_ipv4(ip):
    try:
        # Attempt to create an IPv4Address object from the input string
        ipv4_address = ipaddress.IPv4Address(ip)
        return True
    except ipaddress.AddressValueError:
        # Raised when the input string is not a valid IPv4 address
        return False
async def async_get_number_of_ports(hass, ip_address):
    """Get the number of ports for the device with the given IP address."""
    _LOGGER.debug("Checking number of ports")
    device = MaxSmartDevice(ip_address)
    state = await hass.async_add_executor_job(device.check_state)
    # Logic to determine the number of ports from the state
    # (replace with the appropriate logic for your use case)
    return len(state)
class MaxSmartConfigFlow(config_entries.ConfigFlow, domain=DOMAIN):
    """MaxSmart Config Flow"""
    VERSION = 1
    def __init__(self):
        super().__init__()
        self._errors = {}
        self.devices = []  # The list of devices
        self.device_data = None  # A single device
        self.current_device_index = 0  # Index of the device currently being processed
        self.num_of_ports = None # Number of port for a device
        _LOGGER.debug("MaxSmartConfigFlow initialized")
    async def async_step_user(self, user_input=None):
        """Handle the initial step."""
        self._errors = {}
        if user_input is None:
            return await self.async_step_udp_discovery()
        elif CONF_IP_ADDRESS in user_input:
            # User input includes IP address, perform targeted discovery
            if is_valid_ipv4(user_input[CONF_IP_ADDRESS]):
                return await self.async_step_udp_discovery(user_input[CONF_IP_ADDRESS])
            else:
                self._errors[
                    "invalid_ip"
                ] = "component.maxsmart.config.error.invalid_ip"
                return self.show_ip_address_form()
        elif "add_manually" in user_input and not user_input["add_manually"]:
            return self.async_abort(reason="no_devices_found")
        elif "add_more" in user_input and user_input["add_more"] == "No":
            return self.async_abort(reason="configuration_complete")
        # If we reach this point, we should show the form to ask for an IP address
    def show_ip_address_form(self):
        """Show the form to ask for an IP address."""
        return self.async_show_form(
            step_id="user",
            data_schema=DATA_SCHEMA_MANUAL,
            errors=self._errors,
    async def async_step_add_more_devices(self, user_input=None):
        """Step to add more devices by IP address."""
            step_id="user",
            data_schema=DATA_SCHEMA_ADD_MORE,
    async def async_step_udp_discovery(self, ip_address=None):
        """Perform device discovery and return the results."""
        if ip_address is not None:
            # Targeted discovery for a specific IP address
            _LOGGER.info(
                "Performing UDP unicast discovery towards ip %s on port 8888",
                ip_address,
            self.devices = await self.hass.async_add_executor_job(
                MaxSmartDiscovery.discover_maxsmart, ip_address
        else:
            # Broadcast discovery for all devices on the network
            _LOGGER.info("Performing UDP broadcast discovery on port 8888")
        if self.devices:
            _LOGGER.debug("Devices discovered: %s", self.devices)
            # Process each discovered device
                # Check if a configuration entry already exists for this device
                existing_entry = next(
                        entry
                        for entry in self._async_current_entries()
                        if entry.unique_id == device["sn"]
                    None,
                if existing_entry:
                    _LOGGER.info(
                        "Device %s with name %s is already configured",
                        device["sn"],
                        device["name"],
                    continue  # Skip to the next device
                # Process the data for this device
                return await self.async_step_process_data(device)
            # If you reach this point, all devices have been processed or skipped
            # You can handle the finalization logic here, if needed
        else:
    async def async_step_process_data(self, device=None, user_input=None):
        """Process devices."""
        _LOGGER.debug("Processing device: %s", device)
            _LOGGER.debug("If user input is NONE")
            if device is not None:
                self.device_data = device
            _LOGGER.debug("Self device data is : %s", self.device_data)
            _LOGGER.debug("GETTING IP Address where user input is NONE")
            ip_address = self.device_data["ip"]
            self.num_of_ports = await async_get_number_of_ports(self.hass, ip_address)
            device_name = self.device_data.get(
                "name", ""
            )  # Get the existing device name if available
            # Choose the appropriate schema based on the number of ports and version
            if self.device_data["ver"] == "1.30" and self.num_of_ports == 6:
                _LOGGER.debug("Showing multi-port form")
                schema = DATA_SCHEMA_MULTI_PORTS
            else:
                _LOGGER.debug("Showing SINGLE port form")
                schema = vol.Schema(
                        vol.Required(CONF_DEVICE_NAME, description="Device Name",default=device_name,): vol.All(
#                schema = DATA_SCHEMA_MULTI_PORTS
                step_id="process_data",
                data_schema=schema,
                description_placeholders={
                    "ip": ip_address,
                    "sn": self.device_data["sn"],
                    "np": self.num_of_ports,
                errors={},
        else:
            # Update the name and pname fields of the current device according to user input
            _LOGGER.debug("Processing input and updating data")
            if "device_name" in user_input:
                self.device_data["name"] = user_input["device_name"]
            if self.num_of_ports == 6:
                self.device_data["pname"] = [
                    user_input.get(f"port{i}_name")
                    for i in range(1, 7)
                    if user_input.get(f"port{i}_name")
            else:
                    user_input.get(f"port1_name")
    async def process_import_step(self):
        """Process the import step for all devices."""
                DOMAIN, context={"source": config_entries.SOURCE_IMPORT}, data=device
            step_id="user",
            errors={},
    async def async_step_import(self, device):
        """Create entry for a device"""
        try:
            pname = device.get("pname")
            # sw_version = device.get("ver")
            port_data = {
                "master": {"port_id": 0, "port_name": "0. Master"},
                "individual_ports": [
                    {"port_id": i + 1, "port_name": f"{i + 1}. {port_name}"}
                    for i, port_name in enumerate(pname)
            device_data = {
                "device_unique_id": device["sn"],
                "device_ip": device["ip"],
                "device_name": device["name"],
                "sw_version": device["ver"],
                "ports": port_data,
            await self.async_set_unique_id(device["sn"])
            current_entries = self._async_current_entries()
                (entry for entry in current_entries if entry.unique_id == device["sn"]),
                None,
            if existing_entry:
                _LOGGER.info(
                    device["sn"],
                    device["name"],
                if existing_entry.data != device_data:
                    _LOGGER.info("Updating config entry for device %s", device["sn"])
                    self.hass.config_entries.async_update_entry(
                        existing_entry, data=device_data
                        step_id="import",
                        data_schema=DATA_SCHEMA_OVERWRITE,
                            "ip": device["ip"],
                            "sn": device["sn"],
                        errors={},
            _LOGGER.debug("Creating entry for device %s", device["sn"])
            return self.async_create_entry(
                title=f"maxsmart_{device['sn']}",
                data=device_data,
        except Exception as err:
            _LOGGER.error("Failed to create device entry: %s", err)
            return self.async_abort(reason="device_creation_failed")
I can see the issue but would need to look at it a little more to work out how to resolve.
The issue is in your async_step_process_data function. When you call it and pass the device in, it is fine. However, when you call the show_form, on completion it calls this same function again but does not pass device in again and it is default None. It is only passing user_input whichnis the return from your form schema. You would need to store your original device value as a class level variable to be able to get it back when the form calls your function again.
But I thought i did that by declaring self.device_data in the init method in the class. Is that the wrong place to put it ?
I just cleaned up my mess on github and published release 2023.8-beta1 in the dev branch.
Here it is: GitHub - Superkikim/mh-maxsmart-hass at dev
Sorry yes, much easier to read now on github. Im wondering (and i think from your description of issue is that when the form returns it is passing it to your first parameter which is device and therefore user_input is none. In this case, you are setting self.device_data to your form return.
Swap device and user_input around in your async_step_process_data, so it is…
async def async_step_process_data(self, user_input=None, device=None):
You will then have to change your line 189 to…
return await self.async_step_process_data(device=device)
Didn’t work. Time for me to go to sleep now :sweat_smile: It’s 2am … :woozy_face: :sleeping:
I’ll try again tomorrow. But I will revert to the working version and start again from there. I believe the way I do it right now is too complex, and there is definitely a mistake somewhere :confounded:
Tx for your eyes anyway :slight_smile: I’ll update this thread if/when it works.
