Handy script for while building my dashboards
I run in a dockerized environment, and am just starting with the HAD. I already got tired of docker restart each time I changed something.
I installed inotify-tools on my linux box:
sudo apt install inotify-tools
and now have a script:
#!/bin/sh
cd /home/jamie/had-conf
while inotifywait -qqre modify "./dashboards/"
do
    echo "Change detected"
    docker rm -f appdaemon
    docker run --name=appdaemon -d   -p 5050:5050   --volume /home/jamie/had-conf:/conf myappdaemon
done
I enabled a samba share, and now I just save the dashboard and it automagically restarts for me.
There might be an easier way, but this works :smiley:
And a side note, at least on a mac - if you have Xcode installed you can use the simulator program to get safari running your dashboard (don’t judge the dashboard, I am just trying things):
your dashboards should be outside the docker, so you dont need to rebuild.
and then you can use the recompile settings to automaticly get recompiled dashboards.
They are in fact - I swore that they didn’t update previously, maybe I had something set wrong and fixed it at some point, because now they update fine
Thanks!
