Hangouts is working fine, except when time passes by. Then the problems start.
Here is what happens:
If I restart HA and send a question in Hangouts, it will answer and execute any actions correctly.
If time passes (like 10 minutes maybe) and send a question again, the answer will be repeated a couple of times. Any actions will repeat also.
Waiting a bit more (maybe another 10-20 minutes) all the above is multiplied!
Such a weird behaviour.
I am also getting this error:
Long-polling request failed: Request timed out
The log gives me this:
2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test> 2019-01-30 13:25:21 INFO (MainThread) [homeassistant.helpers.intent] Triggering intent handler <ScriptIntentHandler - test>
It only indicates that the intent is triggering multiple times. But I cant figure out why.
