Has anyone been able to succesfully use that smart plug in Home Assistant ?
I bought mines on monoprice, there are some other very similar looking brands (Zooz for example…)
I have 3 of them, they worked well with smartthings in the past but I have started my switch to HA for a few months now and I haven’t been able to make these working in my home assistant instalation yet.
They pair without any problem and I see a few sensors and the switch entity but flicking the switch from HA doesn’t turn on/off the device and the switch will return to off (when I try turning it on) in HA after a few seconds.
This is what I’ve found in my zwave logs:
2020-01-07 11:00:15.125 Info, Node018, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x12, 0x0a, 0x98, 0x80, 0xeb, 0x74, 0xa3, 0x8c, 0xd1, 0x3c, 0xca, 0xcc, 0x05, 0x01, 0xa2:
2020-01-07 11:00:15.125 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
I imagine (or hope?) I need to do some changes in my zwcfg file to make this work but I have no idea what changes to make. Here is my zwcfg current node configuration: https://pastebin.com/rmkdrUn5
Any help is appreciated.
Thank you
Home Assistant 0.103.5 running on hassio/docker
Zwave stick is AEON Labs ZW090 Z-Stick Gen5 US
