tomoqv
(Tomas)
February 2, 2018, 11:12am
1
I have included a Hank 4-button z-wave scene controller in hass.io . The device shows up in HA with the following attributes:
node_id: 27
node_name: Hank HKZW-SCN04 Scene Controller
manufacturer_name: Hank
product_name: HKZW-SCN04 Scene Controller
old_entity_id: zwave.hank_hkzwscn04_scene_controller_27
new_entity_id: zwave.hank_hkzwscn04_scene_controller
query_stage: Session
is_awake: false
is_ready: false
is_failed: false
is_info_received: true
max_baud_rate: 40000
is_zwave_plus: true
capabilities: beaming,routing
neighbors: 1,10,17
sentCnt: 5
sentFailed: 2
retries: 0
receivedCnt: 0
receivedDups: 0
receivedUnsolicited: 0
sentTS: 2018-02-01 11:47:46:257
receivedTS: 2018-02-01 11:30:16:203
lastRequestRTT: 0
averageRequestRTT: 0
lastResponseRTT: 0
averageResponseRTT: 0
battery_level: 100
wake_up_interval: 0
friendly_name: Hank HKZW-SCN04 Scene Controller
It responds to key presses by changing the values for receivedCnt, receivedUnsolicited and receivedTS, but nothing else. I can’t find any sensors associate with the controller.
Reading the manual, it says that the button can control other z-wave nodes or node groups.
Does anybody know how to set this up in HA? Will I get some sensors if I set associations with some of my other z-wave nodes first?
Help appreciated!
tomoqv
(Tomas)
February 2, 2018, 1:52pm
2
I solved it! Followed the instructions here to edit the zwcfg xml file and adding automations such as:
- alias: Hank Scene Button 1
initial_state: on
platform: event
event_type: zwave.scene_activated
event_data:
scene_id: 1
- service: notify.telegram_bot
message: "Hank scene 1 triggered"
darias
July 8, 2018, 12:19am
3
Any chance you can share your modifications to the zwcfg file? I have the one button controller, and I cannot get it to work. I see a COMMAND_CLASS_CENTRAL_SCENE section in my zwcfg file, but I can’t understand if it needs modification or not.
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="0">
<Instance index="1" />
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
Thanks!
cearum
August 15, 2018, 11:03pm
4
Not OP, but I found in the home assistant docs the Hank One Button :
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="1" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="1" label="Button One" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
Edit: Just in case someone stumbles upon this like I did without a solution present.
turboc
(Chip Cox)
October 19, 2018, 8:17pm
5
For anyone looking for the COMMAND_CLASS_CENTRAL_SCENE section for the Hank 4-button z-wave scene controller. I just got it to work successfully with the zwcfg file section below.
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" issecured="true" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="2" label="Button Two" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="1" index="3" label="Button Three" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="1" index="4" label="Button Four" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
jerame20
(Jeremy Johnson)
September 13, 2019, 10:02pm
6
working on getting the hank 4 button working, i have 17 entries under id 91 did you copy over all of these?
BebeMischa
(Bebe Mischa)
November 7, 2020, 12:36am
7
Thank’s guys,
starting from here, with some more searching, i have managed to get the Hank 4 button where i wanted it. Listenning to me
