Hank motion sensor HKZW-MS02
HI, I have bought 5 z-wave plus motion sensors form the type HKZW-MS02, when adding to Home assistant the status stays in “initializing” mode. Is this sensor not compatible with home assistant?
Is this the state for the zwave entity itself?
Often the zwave entity (for me atleast) will stick at initializing but the sensors work fine.
Did any other sensor or binary_sensor entity ID populate in your states tab related to the new devices? These should update, the zwave state may not change but you can see changes in the attributes as messages are sent.
Hi, it’s the entity itself. And no otter new nodes are added so far.
