I’m quite new to Home Assistant, so apologies if this has been asked before.
Is there any way to control the Hao Deng App + Lumiman Lamp combination in Home Assistant?
Dave
Dave
Never heard of them. What are they? Do you have a link? We are not mind readers.
Hi Dave2112,
Sounds like rano- Tuya based weirdness to me. Always try the Smartlife app and see if it works.
This is the bulb - https://www.lumiman.com/
There’s very little info on the Hao Deng app
OK thanks!
Hao Deng is a Bluetooth mesh derivative of Magic Home, both are under the Zengge name. It’s a confusing labyrinth of apps and protocols. They also have SurpLife, MagicHue, and a few other newer variants.
I haven’t connected my Hao Deng bulbs to HA yet, but there are some GitHub repos that I’ve seen.
UniLED integration for several LED BLE controllers and devices
I tried Uniled but was never able to get it to work with my Hao Deng recessed lights. I ended up writing my own integratio. It only works if you have the wifi bridge, as I reverse engineered their API, so unfortunately no local control
Hi @Pharylon,
Thank’s for this integration, I just test and it works like a charm.
Just one thing, the integration didn’t find my already created groups in Hao deng app, but it’s a detail.
Previously I used this integration which also works but in bluetooth AND without the “router” part : GitHub - SleepyNinja0o/home-assistant-zengge: Zengge mesh light integration for Home Assistant
I installed the integration. It works perfectly for each spot but the groups and scenes are not reassembled in home assistant.
Thank you very much, finally I have integrated Hao deng in home assistant. Very good work much appreciated
