Hello ,
HAOS installed in RPI3 ( version 0.113.3)
To have the remote access available , I have setup both the DuckDns addon and the Letsenscript addon for http challenge ( first step) as per the addon documentation.
The port forwarding 80 - 80 has been also setup in the ADSL Router
When the Letsenscript addon start , it fails with the following errors
- The following errors were reported by the server:
Domain: xxxxx.duckdns.org
Type: connection
Detail: Fetching
http://xxxxxx.duckdns.org/.well-known/acme-challenge/PXcZTB8clLXD2mYNPu2107ThiYQXX9p_Ty9rbhC0ye8:
Timeout during connect (likely firewall problem)
The full log
[18:01:59] INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for xxxxxx.duckdns.org
Waiting for verification...
Challenge failed for domain xxxxxx.duckdns.org
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
Domain: xxxxxxx.duckdns.org
Type: connection
Detail: Fetching
http://xxxxx.duckdns.org/.well-known/acme-challenge/PXcZTB8clLXD2mYNPu2107ThiYQXX9p_Ty9rbhC0ye8:
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
Please any advice ?
Thank you
