I’ve been looking for an add-on for Home Assistant OS that would capture the video output to provide a browser probably showing Home Assistant’s interface in Kiosk Mode.
IMHO it is possible to do so by assigning the video hardware/output to the add-on.
The goal is to use the hardware HAOS is running on as a display source as well.
I guess another method would be to install Proxmox, HAOS in a VM and some other OS in another container or VM with the latter grabbing the video output. But I’ld like to avoid the Proxmox layer and an Add-on would be more accessible to the wider public.
Note: I am not looking for a custom integration as that would not use the display output of the hardware of the HAOS system itself - a kiosk custom integration may be necessary for those that want to run the system in kiosk mode.
