HAOS (baremetal/rpi4) won't boot headless after 2024.11.1
I’m running Home Assistant Operating System on a pi4. This morning there were a few updates including ESPHome (requiring my three Bluetooth proxies to be updated as well). Everything went well until the update for Home Assistant Operating System…
The update froze (seemed to freeze) as it often does, giving no feedback because, its rebooting, I surmise? This is “normal” except, this time, it never recovered. I slowly power cycled a dozen times and decided that this wasn’t going to recover on its own.
My next step was to move the pi4 across the office so I could hook-up a monitor and keyboard to it. Watching the monitor closely for signs of error, it booted up perfectly. I thought, YES!.. just a weird glitch, so I moved it back to its headless resting place and powered it up… Nothing!
I moved it back and gave it a monitor again and magic it boots first time. I’ve been running Home Assistant on this pi4 for about a year and a half, headless.
Am I missing something?
MrGrey.
Hello, I seem to have a similar issue. Not sure what you mean by ‘headless’, but my HA is running also on Pi4, and I just upgraded to 14.1 HA OS, and now, HA won’t start. PI does start, though, and I can ssh into it, and I can run all commands like ha resolution blablabla, but no way I can start HA application.
I never investigated how HA is structured within HA OS, so I do not know where to look for.
OS Version: Home Assistant OS 14.1
Home Assistant Core: 2024.12.4
ha core logs shows the following logs:
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
[13:18:09] INFO: Home Assistant Core finish process exit code 256
[13:18:09] INFO: Home Assistant Core finish process received signal 4
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Does that ring a bell to anybody?
Ah, and I found a home-assistant.log.fault file, containing lots of:
Fatal Python error: Illegal instruction
Thread 0x0000007f929fee58 (most recent call first):
  File "/usr/local/lib/python3.13/logging/handlers.py", line 1523 in dequeue
  File "/usr/local/lib/python3.13/logging/handlers.py", line 1574 in _monitor
  File "/usr/local/lib/python3.13/threading.py", line 992 in run
  File "/usr/local/lib/python3.13/threading.py", line 1041 in _bootstrap_inner
  File "/usr/local/lib/python3.13/threading.py", line 1012 in _bootstrap
Current thread 0x0000007f92fbae58 (most recent call first):
  File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 49 in get_single_data
  File "/usr/local/lib/python3.13/site-packages/yaml/__init__.py", line 81 in load
  File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 228 in _parse_yaml
  File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 201 in parse_yaml
  File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 168 in load_yaml
  File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 186 in load_yaml_dict
  File "/usr/src/homeassistant/homeassistant/config.py", line 276 in load_yaml_config_file
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58 in run
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 92 in _worker
Thread 0x0000007f9e81e020 (most recent call first):
  File "/usr/local/lib/python3.13/selectors.py", line 452 in select
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1989 in _run_once
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 679 in run_forever
  File "/usr/local/lib/python3.13/asyncio/base_events.py", line 708 in run_until_complete
  File "/usr/src/homeassistant/homeassistant/runner.py", line 154 in run
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 213 in main
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 227 in <module>
  File "<frozen runpy>", line 88 in _run_code
  File "<frozen runpy>", line 198 in _run_module_as_main
Extension modules: _cffi_backend, ciso8601, yaml._yaml, propcache._helpers_c, ulid_transform._ulid_impl, multidict._multidict, yarl._quoting_c, markupsa
You are much smarter than I @vbartro.
I mean running without keyboard and monitor.
After Holidays, I’ll try more. For now, it works with a “head” and I can leave it that way.
You are really smarter than I. I disable ssh because cli will only be used by people smarter than I.
I’m pretty sure things will be fixed. It’s better than last year with all of the ZHA failures.
Best wishes to everyone reading this.
MrGrey.
Hi All,
Just a note that I am also seeing this problem on a fresh install of HA on an PI 5. It boots fine with a usb keyboard attached, but not without.
Did you find any solution to your issue?
I forgot about this post and posted about it again, slap me. :smile:
I have no answer and no information except that Home Assistant will boot (for me) as long as I have a monitor and keyboard attached (hardwired) to my pi4 and it won’t start without it.
I can add that it started around 2024.11.x to 2024.12.1, not that, that helps any.
MrGrey.
Edit: Reflecting: (14.1) is 2024.11.1 so I’m changing heading to reflect that.
