HAOS breakdown - hard drive corrupt?
Hallo,
i am german, my english ist not very good. excuse this please.
I have Home assistant OS 9.5 with Hardware Futro S920. I have a USB image with HAOS. USB drive is: Hitachi Sata 3.0 with 320 GB (07-2012) .
Some times, HA breakdown. In most cases i programm something in Node Red plugin.
But it occurs errors in times without i make something.
The hard drive make somethimes unusual noises.
I have no idea in witch way i can test the hard disk. I have no linux knowledge. and there are no available command in HAOS like fsck.
what can i do ?
Thank you for help.
Start the machine from a live usb flash drive, say Ubuntu or Mint. You can check the drive from there, and probably recover data :slight_smile:
Hello nickrout,
thank you for your Post. I try to make a linux live usb stick.
maybe i can make a linux usb stick with only a fsck program. there are a lot usb port by futro S920. if HAOS mount the usb Stick, i can start fsck from the usb stick.
is this possible ? if yes, please give a link to a fsck programm file.
my error log, the messages point to a hard disk defect ?
i have a linux live usb now. tell me the steps.
  1. start linux with live usb
  2. after linux is started, i connect my HAOS usb to the PC with linux live.
    what happen now ? will linux mout automatic the HAOS drive ?
    can you tell me the steps and linux commands i must type
I suggested booting the ha machine with the flash drive.
You’ll need to work out which partition on the ha disk is faulty. Then run fsck on that partition.
good idea, i boot my futro S920 with the linux live usb. and then i run fsck for the HAOS disk.
thank you for your help.
