I’ve been narrowing down my issue with HAOS and what could be causing this and it looks like using NETGEAR’s Nighthawk products makes it so you just cannot download the needed files for HAOS preperation.
22-09-02 11:16:16 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-02 11:16:46 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.8.7
22-09-02 11:16:46 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.8.7.
22-09-02 11:22:21 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.8.7: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.8.7&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-09-02 11:22:21 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
i left it running for an hour and it is stuck in this loop. is anyone aware of a bypass i can use since i am unable to acess the CLI interface?
