We have Home Assistant Operating System (HAOS) installed on a Raspberry Pi and it all works great: 45 devices, 51 automations, 12 blueprints, etc, started about 18 months ago.
EXCEPT automations calling bash scripts… The scripts work fine via
Settings->Automations->[automation]->Run.
Also scripts work fine when run on the Terminal plug-in command line.
BUT the same scripts called by “When time” triggers automation encounters “file not found /usr/bin/rsync” or “aplay: device_list:277: no soundcards found”.
I understand that HAOS runs a containerized HA, but I am mystified that the interactive interface is so different from the automated interface. Surely I am missing an important detail and [troll bait warning] someone can show me the difference so that I can get our scripts working.
Thank you, but the script location is not the problem. In both my examples the scripts are /share/mybin/{backup2share,playtester} and HA is able to invoke them via “when”. The invocation is able to write trace files such as /share/backups/last.txt and /share/tmp/playtester.out
PS, all the same file system in this vanilla deployment:
/config df -m /config /share
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/mmcblk0p8 119594 9459 105237 8% /addon_configs
The Terminal addon one is an addon like any other, i.e. a docker container that basically has nothing in common with HAOS itself besides a couple of shared folders.
You cannot make any assumptions based on the fact that a script will work in the addon.
The only way to properly test your scripts is to ssh to HAOS itself, via:
Thank you… I see that I did not realize the differences between addons and HAOS, now I comprehend:
Terminal contains /usr/bin/rsync, but HAOS does not.
Both can access /config, /share, and several others; these appear as mounted filesystems when running “mount” in the Terminal
The /usr/bin/rsync file resides on filesystem “overlay” of the Terminal addon.
The info you provided contains a dreaded Dragons Be Here warning:
This section is not for end users… This is for developers of Home Assistant.
So, to do this right, I need to assemble another Raspberry Pi for development.
But first–probably not the right way even it works–can I invoke Terminal from HAOS inside an automation? I’m presuming such an invocation could pass along an parameter of what to do.
