I struggled the last two weeks with my kvm and docker server - first I thought, there is a problem with the board, then with Samsung NVME SSD, eventually the power source made problems because of the new CPU. Now, I have a new ATX 3 Power Source and everything is working fine again.
As a matter of fact, I had at a minimum 20 crashes of my system and in the end, HAOS started with an error saying the superblocks of vda8 are bad.
I repaired this issue qemu-img and nbd mount of the 8th partition - I tared the contents, made a new fs in nbd0p8 an extracted the contents back.
The Web-Frontend is working fine - the integrations as well - but when I open the console via virt-manager, then I can only login with root user without pw and ha cli is not the command prompt.
cat /etc/passwd shows no admin user other than root.
When opening a ssh-console to haos with user hassio - the everything looks normal as before.
Opening the terminal in the web-frontend - also normal Welcom to the home assistant command line.
I search via google and in the forum but didn’t find a similar problem. The only thing I found was problems with long duration after the first start on RPIs - but my vm has 3GB, 2 CPUs (Ryzen 5600G) and is idling.
The logins shows itself like this:
Welcome to Home Assistant
homeassistant login: root
Last login: Fri Sep 8 18:18:26 UTC 2023 on ttyS0
Last login: Fri Sep 8 18:18:39 on ttyS0
Welcome to Home Assistant OS.
Use `ha` to access the Home Assistant CLI.
instead of:
$ ssh haos
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
IPv4 addresses for enp0s2: 192.168.2.10/20
IPv6 addresses for enp0s2: xyz...
OS Version: Home Assistant OS 10.5
Home Assistant Core: 2023.9.0
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
I don’t have any idea how to fix this issue.
TIA for any idea
Thomas
