I’m trying to install Home Assistant on my Raspberry PI 4.
I’ve created a sd-card via Etcher, but when I try to start my Pi with the new created image, it doesn’t start.
I can’t see the green LED flashing inside the Pi, after I’ve plugged in the Powercable.
With another sd-Card (with Raspberry Pi OS) it works fine.
Anyone an idea?
Did you download the 64-bit RPi-4 image ? There are multiple RPi images. You need to specifically get the 64-bit one for the RPI-4. Here’s the link for it
Assuming you have used the correct image of HA for a Pi, Try plugging in a monitor if you can, i had the same problem last week plugged in a monitor and had to look up the message that appeared.
@PepperLewis just had a thought if you do a new image of HAOS and that doesn’t work, try just Raspberry PI OS. I’m trying to figure out if your SD card if faulty or is your PI faulty, to me no lights on the PI means it could be dead.
