Hi!
Hopeful this is a stupid question, I am trying to follow steps to update my dashboard.
I have installed Samba, Terminal and File Editor to try to copy files across. However, I’m having great difficulty with it.
I tried to pscp the files into a folder, but unable to.
Now through Samba and connecting to the folder in Windows through the file explorer, I’m unable to rename a folder ‘icons’. I’m not sure if this is a result of me trying to code in the folder previously. using ‘mkdir icons’ under www (which I had also created).
I can see an icons folder in the ‘File Editor’ under what I believe to be the same path, but not able to rename the ‘New Folder’ to icons. SO I think there’s almost a hidden folder of some sort here.
Any help would be much appreciated! Thanks!
