Haos_generic-x86-64-13.3 needed
I don’t suppose anyone has a copy of the latest x86 HA Update that was pulled? I moving from a pi to a nuc but the backup ive got is from 13.3 and can’t update the nuc because 13.3 was pulled.
thanks
It was not the image that was pulled but the supervisor.
There should be nothing wrong with the supervisor update as such, but the distribution method triggered an overload at GitHub.
It is still available on the beta channel.
I think you join the beta channel through Settings → System → Updates → 3 dots in upper right corner.
That’s the solution someone else gave this morning Wally, the update is still available in beta channel because nothing is wrong with the actual code it’s just the distro that’s borked.
So you can switch to beta, pull down the update then switch back to prod.
Perfect, thank you :smile:
