Seems to have a fatal error on my HAOS installation. Sorry for not providing all logs, but the system does not allow me to access or download. Front end (lovelace) is mostly working (can naviagate in the dashboards) but most other menu items are failing (like the few addons I have (terminal, esphome, frigate etc), sensor history is failing and no access to menu items to reboot the system.
Home assistant core log is available, but cannot see anything special other than complaining add-ons are not available. When
Home Assistant Core
Error while processing event EventTask(event=<Event state_changed[L]: entity_id=sensor.temp_teknisk_battery, old_state=<state sensor.temp_teknisk_battery=100; state_class=measurement, event=08500781150000e959, unit_of_measurement=%, assumed_state=True, device_class=battery, friendly_name=Temp Teknisk Battery @ 2023-08-16T12:32:29.888591+02:00>, new_state=<state sensor.temp_teknisk_battery=100; state_class=measurement, event=08500788150000e959, unit_of_measurement=%, assumed_state=True, device_class=battery, friendly_name=Temp Teknisk Battery @ 2023-08-16T12:33:17.892585+02:00>>):
12:33:20 – (ERROR) Recorder - message first occurred at August 15, 2023 at 20:04:52 and shows up 188464 times
Timeout error fetching information from http://ccab4aaf-frigate:5000/api/stats:
12:33:16 – (ERROR) Frigate (custom integration) - message first occurred at August 15, 2023 at 20:02:57 and shows up 5935 times
hci0 (BC:A8:A6:7F:38:FB): Failed to restart Bluetooth scanner: hci0 (BC:A8:A6:7F:38:FB): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: unit failed.
12:33:13 – (ERROR) Bluetooth - message first occurred at August 15, 2023 at 20:07:34 and shows up 1972 times
Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
12:33:00 – (ERROR) Home Assistant Supervisor - message first occurred at August 15, 2023 at 20:06:05 and shows up 2352 times
Catching up, dropped 206 old events.
12:32:07 – (WARNING) InfluxDB - message first occurred at August 15, 2023 at 20:04:52 and shows up 612 times
Error doing job: Task exception was never retrieved
12:30:52 – (ERROR) helpers/storage.py - message first occurred at August 15, 2023 at 20:04:53 and shows up 83 times
[Errno 5] I/O error: '/usr/local/lib/python3.11/site-packages/hass_frontend/frontend_latest/17375-boVibCmoIpM.js'
12:30:39 – (ERROR) components/http/static.py - message first occurred at August 15, 2023 at 21:48:26 and shows up 860 times
Error while processing event StatisticsTask(start=datetime.datetime(2023, 8, 16, 10, 5, tzinfo=datetime.timezone.utc), fire_events=True): The database connection has not been established
12:30:10 – (ERROR) Recorder - message first occurred at August 15, 2023 at 20:05:10 and shows up 199 times
Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
12:29:32 – (ERROR) Home Assistant Supervisor - message first occurred at August 15, 2023 at 21:49:45 and shows up 12 times
Can't read Supervisor data:
12:29:24 – (WARNING) Home Assistant Supervisor - message first occurred at August 15, 2023 at 20:09:24 and shows up 195 times
Failed to to call /addons -
12:20:42 – (ERROR) Home Assistant Supervisor - message first occurred at August 15, 2023 at 21:50:04 and shows up 55 times
Client error on /addons request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
12:20:42 – (ERROR) Home Assistant Supervisor - message first occurred at August 15, 2023 at 21:50:04 and shows up 56 times
Error handling request
12:14:36 – (ERROR) Frigate (custom integration) - message first occurred at August 15, 2023 at 21:48:39 and shows up 27 times
For the supervisor logs, I get this error message:
Restarting HA does not make any difference, and full system reboot is not available any more.
Is there a way to force reboot from remote or repair / restart supervisor?
