HAOS has been a nightmare and I am planning on moving off it eventually, but I would really don’t have time and would like to find a temporary fix. It seems a little bit odd that even the console would lock up.
The last logs written before it locks up don’t provide much information.
2024-12-21 21:10:36.938 homeassistant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
2024-12-21 21:26:14.104 homeassistant kernel: audit: type=1334 audit(1734816374.102:336): prog-id=90 op=LOAD
2024-12-21 21:26:14.104 homeassistant kernel: audit: type=1334 audit(1734816374.102:337): prog-id=91 op=LOAD
2024-12-21 21:26:14.104 homeassistant kernel: audit: type=1334 audit(1734816374.102:338): prog-id=92 op=LOAD
2024-12-21 21:26:14.113 homeassistant systemd[1]: Starting Hostname Service...
2024-12-21 21:26:14.456 homeassistant systemd[1]: Started Hostname Service.
2024-12-21 21:26:14.473 homeassistant kernel: audit: type=1334 audit(1734816374.471:339): prog-id=93 op=LOAD
2024-12-21 21:26:14.474 homeassistant kernel: audit: type=1334 audit(1734816374.472:340): prog-id=94 op=LOAD
2024-12-21 21:26:14.474 homeassistant kernel: audit: type=1334 audit(1734816374.472:341): prog-id=95 op=LOAD
2024-12-21 21:26:14.486 homeassistant systemd[1]: Starting Time & Date Service...
2024-12-21 21:26:14.781 homeassistant systemd[1]: Started Time & Date Service.
2024-12-21 21:26:44.469 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2024-12-21 21:26:44.513 homeassistant kernel: audit: type=1334 audit(1734816404.511:342): prog-id=92 op=UNLOAD
2024-12-21 21:26:44.513 homeassistant kernel: audit: type=1334 audit(1734816404.511:343): prog-id=91 op=UNLOAD
2024-12-21 21:26:44.513 homeassistant kernel: audit: type=1334 audit(1734816404.511:344): prog-id=90 op=UNLOAD
2024-12-21 21:26:44.817 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
2024-12-21 21:26:44.849 homeassistant kernel: audit: type=1334 audit(1734816404.847:345): prog-id=95 op=UNLOAD
2024-12-21 21:26:44.849 homeassistant kernel: audit: type=1334 audit(1734816404.847:346): prog-id=94 op=UNLOAD
2024-12-21 21:26:44.849 homeassistant kernel: audit: type=1334 audit(1734816404.847:347): prog-id=93 op=UNLOAD
