HAOS Nabu Casa config and SSL on IP
Hello all,
I have HAOS configured with Nabu Casa and all is working good.
I have also 3 webhooks configured for a local network call (http://192.168.x.x:8123/api/webhook/buttonPressed), but the plugin I’m using for call it only works with https address. I tried to call https://192.168.x.x:8123/api/webhook/buttonPressed, but I receive a protocol error, because my HA works in local only using http, not https.
Mi goal is: how can I configure HAOS to use SSL if I call from local network?
Thank you.
HTTP - Home Assistant. Has a lot of info about this.
Much more already written info can be found be searchng the home assistant website.
Tips on Searching for Answers & Duplicate Topics in the Forum.
Unless there is miscommunication, you already have a https://<foobar>.my.nabucasa.domain address, don’t you?
Thank you, I already saw that link, but didn’t find something usable… could you please help me to find the infos there?
Exactly, I have a xxxxx.ui.nabu.casa working address, but I want to call this endpoints using LAN address.
That should work
As specified in the first post, I nedd to execute wekhooks in local, not using external address, because if I lose internet, the webhook cannot be called. So I’m looking a guide to configure SSL in address homeassistant.local:8123
Then you need to install a proxy server like nginx in front of HA. I use https://home.mydomain.com locally.
Smells like a good google phrase, if you ask me :wink:
EDIT: Note that it will hardly work with a “.local” domain name (and local dns names in general), due to the inability to get a public SSL certificate for those (at least afaik), so you’ll also need to be sure you can switch the verification off in whatever will call the webhooks.
Tack that after
site:home-assistant.io
in the google string and you have a winner…
I already saw that guides… all includes cloudflare configuration using tunnels for external access that I don’t need.
At the end of the day:
  1. Get a ssl certificate
  2. Link to it in configuration.yaml (ssl_certificate + ssl_key)
Thank you, tried with nginx and similar, but the solution was simple…
