Hello.
Running Home Assistant OS core-2025.2.4.
I recently updated dahlb/ha_carrier
which introduced a dependency update to carrier-api==1.17.0
. However, it does not seem that the carrier-api module has been updated, which is causing errors as ha_carrier depends on new features in the library.
From the ssh shell we can see 1.16.2 is installed
[core-ssh ~]$ ls -1d config/deps/carrier_api*
config/deps/carrier_api-1.16.2.dist-info
[core-ssh ~]$ ls -1d config/python/carrier_api*
config/python/carrier_api-1.16.2.dist-info
However, we can see that ha_carrier is updated and specifies 1.17.0
[core-ssh ~]$ grep 'requirements' config/custom_components/ha_carrier/manifest.json
"requirements": ["carrier-api==1.17.0"],
I looked through the logs, but didn’t see any messages that would have been related to updating carrier-api
. I’m sure I’m missing something obvious, any insight would be much appreciated.
Thanks!
