HAOS on Proxmox network issues
I installed HAOS on Proxmox using this documentation: https://www.wundertech.net/how-to-set-up-home-assistant-on-proxmox/
I did in manually.
Since Home Assistant is running this way, i have a lot of connection issues. For example, i have connection issues to MQTT (running on an other VM).
Also the log shows a lot of connection issues.
I was running HA Supervised on Debian however i thought it was a good idea to move to HAOS since this is the recommended installation type.
Any ideas?
Try the following, you might have better luck.
