HAOS on VirtualBox and Rhasspy
I’ve been running HA for over a year now on VirtualBox (Windows 11) with no issues. Recently I’ve been trying to add a way to make voice commands work. I installed Rhasspy Assistant on my HAOS which is, like I already said, on VirtualBox. I have audio input and output selected on my virtual machine settings as well as an additional USB sound card which is detected by HAOS (at least it appears on with the other hardware in HA settings).
I have tried many times to select the default input and output (which I can only assume is what is plugged directly into the motherboard and Windows uses as defaults) as well as the usb soundcard input and output in the configuration tab of Rhasspy before starting it.
The issue is that the speakers in Rhasspy work fine, but the mic doesn’t. When I test the PyAudio, nothing works.
Any ideas?
