HAOS on Yellow CM5 with eMMC
I have purchased the following HW:
  • Home Assistant Yellow Standard Kit - smart gateway - ZigBee / Thread - Nabu Casa YELLOW-KIT-STD
  • Raspberry Pi CM5 Compute Module 5 - 4GB RAM + 32GB eMMC + WiFi/Bluetooth - CM5104032
I am following the standard installation procedure for the Yellow. Everything works well until this step:
I can select the Rasperry Pi device, the Operating System but I cannot select any storage. The internal eMMC storage is not detected. There is nothing in the pop-up list.If I plugin an external USB memory stick into the Yellow, it is detected as a storage and installation can proceed.
In the forums, it says that the Imager should be able to flash directly onto the CM5 eMMC but that doesnt seem to be the case.
So, I have tried to run first the CM4/CM5 Mass Storage Gadget but that doesn’t work as the Yellow board does not have the pins that disable booting from the eMMC prior to flashing the OS.
And so I get stuck here and installation cannot proceed.
Any help would be greatly appreciated
Thanks so much
It ended up working by running again rpiboot-CM4-CM5 - Mass Storage Gadget
