Trying to get a Coral TPU working with Frigate under HAOS running via a Proxmox VM.
System
Dell 7040
Core i5 6500
40 GB RAM
Home Assistant 2023.5.2
Supervisor 2023.06.2
Operating System 10.1
Frontend 20230503.3
Using dual edge TPU on an M.2 to PCI-E adapter - I’m aware only one TPU will show/work, this isn’t an issue at the moment.
PCI Passthrough should be setup and working, but this could be the issue.
The device is passed through to HAOS and /dev/apex_0 exists under HAOS
Frigate sees the Coral device as a detector under the config part of the UI but gives errors about no EdgeTPU being detected in the logs
Unfortunately Frigate crashes after a minute or so with the following in the Frigate log
2023-06-24 14:38:36.468180251 [2023-06-24 15:38:36] detector.coral INFO : Starting detection process: 227
2023-06-24 14:38:36.468183620 [2023-06-24 15:38:36] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as pci
2023-06-24 14:38:36.469141208 [2023-06-24 15:38:36] frigate.detectors.plugins.edgetpu_tfl ERROR : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2023-06-24 14:38:36.470747302 Process detector:coral:
2023-06-24 14:38:36.470750193 Traceback (most recent call last):
2023-06-24 14:38:36.470751572 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2023-06-24 14:38:36.470752697 delegate = Delegate(library, options)
2023-06-24 14:38:36.470755531 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2023-06-24 14:38:36.470770200 raise ValueError(capture.message)
2023-06-24 14:38:36.470771530 ValueError
2023-06-24 14:38:36.470772502
2023-06-24 14:38:36.470774169 During handling of the above exception, another exception occurred:
2023-06-24 14:38:36.470775164
2023-06-24 14:38:36.470776174 Traceback (most recent call last):
2023-06-24 14:38:36.470777370 File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2023-06-24 14:38:36.470796621 self.run()
2023-06-24 14:38:36.470797941 File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2023-06-24 14:38:36.470799111 self._target(*self._args, **self._kwargs)
2023-06-24 14:38:36.470800243 File "/opt/frigate/frigate/object_detection.py", line 98, in run_detector
2023-06-24 14:38:36.470814185 object_detector = LocalObjectDetector(detector_config=detector_config)
2023-06-24 14:38:36.470815412 File "/opt/frigate/frigate/object_detection.py", line 52, in __init__
2023-06-24 14:38:36.470816584 self.detect_api = create_detector(detector_config)
2023-06-24 14:38:36.470817770 File "/opt/frigate/frigate/detectors/__init__.py", line 24, in create_detector
2023-06-24 14:38:36.470818811 return api(detector_config)
2023-06-24 14:38:36.470819972 File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 37, in __init__
2023-06-24 14:38:36.470821148 edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2023-06-24 14:38:36.470834973 File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2023-06-24 14:38:36.470836198 raise ValueError('Failed to load delegate from {}\n{}'.format(
2023-06-24 14:38:36.470837290 ValueError: Failed to load delegate from libedgetpu.so.1.0
There is also the following under dmesg
RAM did not enable within timeout
Error in device open cb: -110
Any ideas or suggestions to fix this?
Feel like I’m nearly there since it is seen in HAOS under /dev
