It’s taken me a bit because I rebooted it twice after the last freeze (system update). Today, it was frozen, again (even a cursor wouldn’t move in terminal!). Curiously, virtualbox process was at MAX CPU (400%, it has 4 vCPUs).
After rebooting, I can see hundreds of thousand errors due to “Dahua” integration (camera) for one specific camera which is currently disconnected due to a faulty cable.
I removed that device and it will see if it was that!
Errors:
2024-11-20 19:29:55.338 ERROR (MainThread) [custom_components.dahua] Failed to initialize device at 192.168.99.90
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1109, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
File "/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py", line 104, in start_connection
raise first_exception
File "/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py", line 82, in start_connection
sock = await _connect_sock(
File "/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py", line 174, in _connect_sock
await loop.sock_connect(sock, address)
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 641, in sock_connect
return await fut
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 681, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.99.90', 80)
File "/config/custom_components/dahua/__init__.py", line 203, in _async_update_data
self._max_streams = await self.client.get_max_extra_streams() + 1
File "/config/custom_components/dahua/client.py", line 141, in get_max_extra_streams
result = await self.get("/cgi-bin/magicBox.cgi?action=getProductDefinition&name=MaxExtraStream")
File "/config/custom_components/dahua/client.py", line 792, in get
raise exception
File "/config/custom_components/dahua/client.py", line 774, in get
response = await auth.request("GET", url)
File "/config/custom_components/dahua/digest.py", line 46, in request
response = await self.session.request(method, url, headers=headers, **kwargs)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 663, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 538, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1050, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1384, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1353, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1124, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.99.90:80 ssl:default [Connect call failed ('192.168.99.90', 80)]
2024-11-20 19:29:55.340 ERROR (MainThread) [custom_components.dahua] Unexpected error fetching dahua data
return await fut
