Unsupported system - OS-Agent issues System is unsupported because OS-Agent is missing, inactive or misconfigured. Use the link to learn more and how to fix this.
I run HAOS on VirtualBox without any problem before, how can i fix that ?
This isn’t related to 2022.11. If you’re seeing these repairs in 2022.11 then your system was unsupported for the same reasons prior to 2022.11. You just didn’t notice because the warnings were hidden away, 2022.11 simply made what was already there more obvious. For a more detailed explanation of this, see here.
Did you click the more info link in each one? It tells what is wrong and how to fix it.
EDIT: Also I see “Unsupported system - Operating System” which means you are not using HAOS. What do you actually have in the virtualbox? And if you are using virtualbox anyway why not just use HAOS?
Oh I’m sorry I was looking at a screenshot below your post. My fault.
What version of HAOS are you running? HAOS has come with OS Agent pre-installed and ready to go since v6.0, are you running on v5 or older? If not then perhaps try rebooting the machine, maybe something crashed.
