I have a new PC where I am installing Home Assistant as new.
Home assistant is running in HA OS as a VirtualBox guest VM running on Windows 11 Home.
This can happen any time through the day but typically at night.
I have the HA OS VM console visible and running to troubleshoot the issue and appears to be up and running during the troubled time.
If I open VirtualBox to see what it has to say about the VM, I see the following two logs appear in the HAOS console:
- systcmd[1]: systcmd-udcvd.service: Watchdog timeout (limit 3min)!
- systcmd-coredump[1976001]: Process 87208 (system-journal) of user 0 terminated abnormally without generating a coredump.
After these two logs are posted - everything is working again. I do not need to restart HA or the VM.
VM issue, HAOS issue??
System configuration:
HA OS Version: 12.4, HA Core: 2024.7.4
VirtualBox 7.0.20 r163906 (Qt5.15.2)
Host: Windows 11 Home, 23H2, OS build 22631.3958
VM assigned 2 CPU, 2G RAM
Windows power management - disable sleep - same for network adaptor
VM Network adaptor is in Bridged Mode, Promiscuous - Allow all.
Can anyone think of something that I should consider?
