HAOS Web Interface cant be accessed - HA Core crashing due to "Auth Providers"
I got HAOS working on my Pi the last week and have been running it without issue with a the File Editor, SSH and NGINX Proxy Manager addons installed, and a handful of integrations.
This morning I woke up to it being inaccessible via the web interface both locally and externally, it simply just refuses to connect. However the observer URL works fine and I am able to connect to the PI using SSH.
When observing the HA core logs I see this in a loop every couple minutes -
[07:51:23] INFO: Home Assistant Core finish process exit code 1
[07:51:23] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 174, in main
    args = get_arguments()
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 84, in get_arguments
    from . import config as config_util
  File "/usr/src/homeassistant/homeassistant/config.py", line 28, in <module>
    from .core_config import _PACKAGE_DEFINITION_SCHEMA, _PACKAGES_CONFIG_SCHEMA
  File "/usr/src/homeassistant/homeassistant/core_config.py", line 19, in <module>
    from . import auth
  File "/usr/src/homeassistant/homeassistant/auth/__init__.py", line 30, in <module>
    from .providers import AuthProvider, LoginFlow, auth_provider_from_config
ImportError: cannot import name 'AuthProvider' from 'homeassistant.auth.providers' (unknown location)
This hasn’t come up before, my config doesn’t include and auth providers block but I did try including one with trusted proxies and homeassistant added but this has no effect
Like this -
homeassistant:
  auth_providers:
   - type: homeassistant
   - type: trusted_networks
     trusted_networks:
            - 192.168.1.0/24
            - 172.30.22.0/24
My existing config is this -
default_config:
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.1.0/24
    - 172.30.22.0/24
  login_attempts_threshold: 500
  ip_ban_enabled: false
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
Any ideas as to how to fix this?
Many Thanks!
Right so rolling back two versions of core and then updating again worked. Still confused as to the issue cause but back online now.
