HAOSS install on x86 does not detect my 10G nic (Gtek or HP523SFP)
When trying to install HAOSS on x86, everything is fine except the fact that only 1G internal nics are detected. Tried HP523SFP 10Gbps and INTEL 82599EN SFP, in both case no detection.
I tried connecting internal 1G during install process in order to get some drivers if automaticly needed during install but there’s no differences.
Facing those issues, I decided to go for a supervised install .
When I install a fresh debian 12, everything works until I install the first required packages that lead me to loose DNS (well known bug on debian 12 install or update). The proposed solutions I’ve found over numerous forums are not working at all.
As I need to install Frigate Addon just after HA, I need HAOSS or Supervised HAOS via debian 12 install only. Other install won’t let me install Frigate correctly.
Do you have any Idea about How to have HA+Frigate+10Gb Nics working together ?
Hey, did you ever find a solution to HA not detecting the SFP+ ports?
