Happpy Bubble and XY3
I have a problem with happy bubble and XY3 ibeacon. I watched a video on youtube. Everything went well. But the problem is that in HA the ibeacon doesn’t change its state. If the xy3 is far away and I restart HA after the reboot it shows away. After I go to the happy bubble the state is changed to the name of the happy bubble. But after that it’s stuck on that name.
Thanks.
Did you install the Happy Bubbles presence server? If yes, under Settings, uncheck “only send changes in location to home assistant”. With mqtt_room, a device is only marked away when it stops getting mqtt traffic about that device after the away_timeout parameter has expired. If you remove the away_timeout parameter in mqtt_room, the device will probably never be marked away…
Yes, thank you. That was the problem. The youtube video which I have watched I don’t why but they deleted this row. Thanks again.
