for me no data on this topic …
mosquitto_sub -h 192.168.10.8 -p 1883 -v -t "happy-bubbles/presence/changes" -u hadash -P hadash
why suddently it stops to work ?
I thought that the topic used by ha was :
happy-bubbles/presence/ha
the following command returns me that :
mosquitto_sub -h 192.168.10.8 -p 1883 -v -t "happy-bubbles/presence/#" -u hadash -P hadash
happy-bubbles/presence/ha/home {"id":"d2c4317d2737","name":"miband3","distance":95}
happy-bubbles/presence miband3 is most likely in home with average distance 95.000000
happy-bubbles/presence/ha/home {"id":"c1f42791752e","name":"NutBlanc","distance":88.66666666666667}
happy-bubbles/presence NutBlanc is most likely in home with average distance 88.666667
happy-bubbles/presence/ha/home {"id":"ceeb5d1bea5f","name":"NutOrange","distance":75.33333333333333}
happy-bubbles/presence NutOrange is most likely in home with average distance 75.333333
After a restart HA i have many reconnection in MQTT
May 11 17:23:42 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:44 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:46 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:48 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:50 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:52 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:54 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:56 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:23:58 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:00 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:02 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:04 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:06 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:08 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:10 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:12 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:14 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:16 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:18 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:20 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:22 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:24 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:26 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:28 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:30 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:32 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:34 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:36 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:38 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:40 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:42 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:44 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:46 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:48 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:50 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:24:52 gano-vm hass[5958]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server
each 2 seconds…
and with the complete trace
May 11 17:55:40 gano-vm mosquitto[24433]: Client hadash already connected, closing old connection. May 11 17:55:40 gano-vm mosquitto[24433]: Client hadash disconnected. May 11 17:55:40 gano-vm mosquitto[24433]: New client connected from 192.168.10.49 as hadash (c0, k60, u'hadash'). May 11 17:55:40 gano-vm mosquitto[24433]: New connection from 192.168.10.8 on port 1883. May 11 17:55:40 gano-vm hass[9023]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:55:40 gano-vm hass[9023]: INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.webcamsurf to 192.168.10.21 (auth: False) May 11 17:55:41 gano-vm mosquitto[24433]: Socket error on client <unknown>, disconnecting. May 11 17:55:41 gano-vm mosquitto[24433]: New connection from 192.168.10.8 on port 1883. May 11 17:55:41 gano-vm mosquitto[24433]: Client hadash already connected, closing old connection. May 11 17:55:41 gano-vm mosquitto[24433]: Client hadash disconnected. May 11 17:55:41 gano-vm mosquitto[24433]: New client connected from 192.168.10.8 as hadash (c1, k60, u'hadash'). May 11 17:55:42 gano-vm mosquitto[24433]: New connection from 192.168.10.49 on port 1883. May 11 17:55:42 gano-vm mosquitto[24433]: Client hadash already connected, closing old connection. May 11 17:55:42 gano-vm mosquitto[24433]: Client hadash disconnected. May 11 17:55:42 gano-vm mosquitto[24433]: New client connected from 192.168.10.49 as hadash (c0, k60, u'hadash'). May 11 17:55:42 gano-vm mosquitto[24433]: New connection from 192.168.10.8 on port 1883. May 11 17:55:42 gano-vm hass[9023]: INFO:homeassistant.components.mqtt:Successfully reconnected to the MQTT server May 11 17:55:43 gano-vm mosquitto[24433]: Socket error on client <unknown>, disconnecting. May 11 17:55:43 gano-vm mosquitto[24433]: New connection from 192.168.10.8 on port 1883. May 11 17:55:43 gano-vm mosquitto[24433]: Client hadash already connected, closing old connection. May 11 17:55:43 gano-vm mosquitto[24433]: Client hadash disconnected. May 11 17:55:43 gano-vm mosquitto[24433]: New client connected from 192.168.10.8 as hadash (c1, k60, u'hadash').
nobody has problem with MQTT (mosquitto) following the last update of HA ? even with a downgrade HA in 0.41.0 the detection works 3 minutes and stops to see me at home (away)… But messages are still posted in mosquitto … it seems that ha stops to get them …
