HAProxy, Home Assistant won't stay logged in
Hi all,
I have Home Assistant working through HAProxy (hosted on Pfsense), in that it can be accessed and you can login. But each time you hit refresh, it logs you out.
I did some searching and found some topics related to websocket issues, etc. So in HAProxy I added “timeout tunnel 3600s” on the relevant backend → advance settings → backend pass thru.
This hasn’t fixed the issue. Am I on the wrong track?
Cheers,
Justin
doh, well I feel silly, the same behaviour happens if I access HA directly, and not via the proxy. I guess that is by design?
