Hi all,
With the hardware box from home assistant, is it possible to install a mqtt broker on it?
Hi all,
Yes, it is.
Home Assistant Blue?
Yes, this is a standard Home Assistant OS image running on an Odroid N2+ (with a fancy case).
So you can install any addon that supports the ARM architecture, which includes the Mosquitto addon.
Ok thanks!!!
How about letsencrypt, is that also possible on the hardware box?
Check the docs but I’m pretty sure it does.
