I have an industrial pump system (think small splash pad) that operates on a primitive mechanical timer in “auto” mode, but has a wire loop that enables / disables the pump when in “hand” or manual operation. so effectively, I can set it to auto, and use the mechanical timer, or set it to hand, and open or close the circuit on a single din rail jumper to trigger the on / off of the pump.
I’d like to use HA to automate the on/off based on time and weather parameters, and also enable manual remote overrides for on or off.
I’m looking for a hardware device that can be controlled by HA, that will just open or close the circuit. Z wave is pre existing in this location, but could also be hardwired somehow. I believe it is 12vdc, but to be honest, I’d have to check if that is critical.
Voltage is always critical when building something.
Also add some diagrams of what the circuit looks like and/or pictures.
It will make it a lot easier to help
