I would like some help with monitoring HW temperature in Home assistant. So far, i didn’t face the need to do so but yesterday the fan of my PC stopped working and temperatures increased in critical levels.
I run Home Assistant on virtual machine on Windows and as far as i know, Virtual Machines don’t have access to HW level information. While searching, i found the Open Hardware Monitor which i tried but unfortunately i couldn’t make it work (not even the web server).
Is there any alternative that you might be aware off?
What i am interested is to get fan speed and System and CPU temperature in Home assistant so i can get alerts if the RPM is too low and temperatures too high.
At first thank you for the effort and for sharing additional documentation.
I guess you are right, everybody speaks about MQTT it just that i didn’t need it so far. For a bit more than a year, everything works fine with Tuya and Zigbee (ZHA) and i didn’t have a need for more advanced sensors.
The latest addition was ESPHome for an underwater temperature sensor but that’s it. Ok then, learning time
